It's a really nice day here in Baltimore today, so I decided to take my '06 TJ out to play. I went to the same county park I usually poke around at. The county park isn't a park in the sense that there's no playgrounds/campsite or anything like that. It's basically a couple picnic shelters and public hunting/fishing grounds with some dirt/gravel roads that wind around/through it. Now, it's nothing spectacular, nothing you would really consider "wheeling", but there are a couple places you can get off the roads per se and get the Jeep a little dirty. Everything I've done up there so far is pretty mild, nothing that would put me at any risk of becoming stuck or damaging the Jeep.
Keep in mind that it rained all night last night.
I was going up a road I had been up once before that winds up the side of a hill. Again, the road is gravel and doesn't require 4WD. This particular road leads out of the park. At the top of the hill is a clearing off to the left that goes over the hill...roughly 75-100' wide, which follows the path of power lines running up the hill. On my only previous drive up this road, I noticed a trail heading off towards the power poles, presumably an access road for the power company. For some reason I thought there were houses go by and/or I was afraid of getting in trouble for trespassing and I didn't try the trail.
Today, as I came up on the trial there were no houses around, and looking I saw no signs saying "no trespassing" or "do not enter". I'm not sure if this piece of land was actually on the park property or not...but I decided to try it. Mistake number 1.
Remember, I said it rained all night last night?? Well this trail was pretty soggy, lots of mud. I had it in 4WD Hi and for the first 3-400 yards down the trail I was ok, but the mud got progressively worse. My TJ is mechanically stock, stock wheels/tires (30" wheel/tire group, i.e. 30" Goodyear GS-A's - not exactly a mud tire). I also have no winch (mistake #2), didn't have my tow straps with me because I didn't plan on doing anything extreme (mistake #3) and I was by myself (mistake #4). Oh yeah, to make matters worse, back in the hills here there was no cell phone service (mistake #5).
So anyway, after 300 yards or so of plowing down the trail, I realized this probably wasn't a good idea (see above). I came upon a fork in the trail, where the trail was a bit wider and decided to try and turn around. This was on a slope from right to left. I went high and tried to turn around to the left, but I got stuck in a big rut. I wiggled the front tires back and forth, tried backing up, etc, but I couldn't get out. I tried 4WD Lo, same results. I kept slipping down the hill towards the edge of the trail as I was trying to get out of the rut. I finally gave up and shut the engine off and got out to see how bad it looked. After assessing the situation, I decided my only options were to A) try to walk to the top of the hill to get phone service and call my brother in law to see if I could talk him into coming out to try and pull me out with his truck, B) Go looking for the nearest house to try and find someone to help get me out, or C) There was some brush on the edge of the trail I could drive through. There was a power pole in the way, but I thought I had enough clearance that if I could get traction in the brush that I could swing around the power pole and get facing the right direction. Then with a little luck I could plow back up the trail and get out of there. I decided to try plan C. I got down in the brush and was able to swing the front end around and got it facing the right direction. Then I popped it into reverse and gave it a good bit of right foot and that popped me out of the rut. I was then able to get back up the trail the other way and got off the trail on my own with no damage to the Jeep.
So there's my story. Now for my question - in a situation like I was in this morning where you're nearly stuck in mud, is there any advantage to using 4-LO over 4-HI?? I mean, I understand 4-LO is lower gearing which would be better for climbing over rocks/logs/etc, but in mud does it really make a difference? It really didn't feel like it, but I'm still new to this off-road thing, so maybe my driving technique is/was the problem? Any ideas??
Feel free to bash me for getting in over my head too, I deserve it
. I'm not going to say I won't try this trail again, as it was a ton of fun after I knew I was going to make it out, but next time I'll either have someone to pull me out or I'll at least wait several days after it rains
Edit: Mods, I'm not sure what the proper place for this thread would be - if it would be more appropriate in the General Chat forum, please move it. Thanks!
