J jeepsterwr New member Feb 8, 2004 #1 My 4WD light went out about 3 months ago on my 99 TJ. Is there a simple way to fix this or does it involve some major removal of the instrument panel. ??
Snitty New member Feb 8, 2004 #2 if it is the lamp, you'll have to remove the instrument panel. it's really not that big of a job
Bounty__Hunter Super Moderator Feb 8, 2004 #3 Man, and I was ready to answer that question pertaining to a YJ :lol: How is the 4wd light activated on a TJ? If it's on the transfer case lever, the switch may be out of adjustment. I dunno.
J jeepsterwr New member Feb 9, 2004 #4 will this fit??? This is ativated when you pull up on the 4WD lever whereby it automatically goes on
Bounty__Hunter Super Moderator Feb 9, 2004 #5 jeepsterwr said: This is ativated when you pull up on the 4WD lever whereby it automatically goes on Click to expand... Really :roll: Okay, seriously, what type of switch activates the light 'when the little lever thingy is pulled back'
F frankiefire702 New member Feb 10, 2004 #6 i believe the tranfer case mode switch directly on the side of the transfer case works the light on the dash.
