pinaplebob
I'm looking to replace my smashed up gas tank that came on my CJ5. I've been underneith the thing multiple times now, and it appears that thing is bolted in the back two corners, and there is one bolt centered in the front.
Every place i've found that stocks the tank says something about straps being required to hold up the tank. What the heck am I missing? I'm certain it is not a replacement/aftermarket tank, but i could be wrong. (Fit is prefect, and bolt holes line up perfectly).
When I did the tank on my '78 it had straps, and I don't see anything in common between the two back there.
Thank you for your respons
