airing down
Gspotracing
Does anyone know how low you can go on tire pressure for 33/12.5/15, and not debead the tire? The lowest i've gone is about 20 psi. This would be for rock crawling. :evil: [addsig]
1065863
Heck just the other day i aired mine down to something like 15-18 and was driving on them for a week and they didn't debead.[addsig]
1065939
I usually air down to 15 psi and haven't had a problem yet although the sidewalls look a little close to the ground. Some of the guys I go 4-wheelin with air down to 8 psi with 33" swampers without beadlocks and I haven't seen them have any problems yet.[addsig]
1065942
thank you for the info :evil: [addsig]
1065989
Remember, different brand tires can handle lower pressures, like bias-ply swampers can run to single digits with no problem, with such stiff sidewalls. Most other tires can't be run so low.[addsig]
1066061
No, MT/R's sidewalls are not as stiff as the Bias Swamper. Trail and error here, just see what works for you. Start at about 18 and I wouldn't go below 12 or so.[addsig]
1066064
My buddy used to drop his 32x11.50's to 10 (BFG AT) down at Pismo (a big sand terrain park)[addsig]
1066313
Hay g the last time we went to hollister did we even air down. You did just fine in all those rocks. [addsig]
1066319
Hey JE420EP where do you live? I live in morgan hill (between San Jose and Gilroy). We should go wheelin sometime!! And do you plan to go to the jeepz week in TN?[addsig]
1066465
Shane, je420ep and I both live in salinas, CA. We are going to hollister this weekend. Would you like to hook up? :evil: [addsig]
1066469
Just a little bit out of the way.
If you want to do some wheeling just let us know and we can hook up some time. By the way what are you driving.
edited by: JE420EP, May 02, 2003 - 04:12 AM[addsig]
1066641
I use 18 offroad, but wouldn't go below 12psi. It all depends on terrain, driving skill, and rim type.
I have no skill so i'll just stay home :evil: [addsig]
1066651
It has ALOT to do with the size rim you are using. acceptable PSI for a 33in. has less to do with the height of the tire than with the width of the tire compared to the rim. if you are running a 33x12.50 on a 15x8 rim, you should be able to air down quite a good bit. However if you are running the same tire on say a 10.50, you cannot air down as low without blowing the bead.[addsig]
1066676
What does skill have to do with low psi. If it's going to blow it's going to blow. I think it all depends on the tire and rim.[addsig]
1066746
Thank you Mr. 420. :evil: [addsig]
