Bleeding Slave Cylinder of 95 YJ
PatrickPresti
Hey Guys,
Just replaced my master clutch cylinder on my 95 YJ 2.5L because it was shot. The clutch pedal is very soft. There is virtually no pressure on it when pushing down on it.
I topped off the fluid and I was going to bleed the slave cylinder. However when I try to bleed the system and open the bleeder screw, no fluid comes out. I popped the line off going to the slave cylinder and fluid does come out when I push down on the pedal.
Any thoughts? Thanks.
Try removing the bleeder entirely, just in case it's clogged in any way.
