It is on the transmission app 90 deg from the shifter to the passenger side. But first check the wiring from the reverse lights back to the switch. You likely have a short somewhere and the switch is working properly.94 yj 6 cylinder 5 spd manual, the fuse for the gauges, buzzer,and backup lights is the same fuse. When I put it in reverse it blows the fuse, figure it must be the switch for the back up lights. Can anyone tell me where that switch is located.
Ok cool, thanks. Is it possible I may have disturbed anything, like a n oil seal, cause I noticed I had no oil leaks at all ,haveing me think I may have a pretty tight veichle for it's age.
I tend to think it is the switch, I took the backup lights out and put it in reverse and it blew a fuse. My thinking is that with the bulbs out that makes an open circuit and so it must be the switch, anybody got any thoughts. I'm kinda limited in electrical knowledge.It is on the transmission app 90 deg from the shifter to the passenger side. But first check the wiring from the reverse lights back to the switch. You likely have a short somewhere and the switch is working properly.
Agree with JPNinPA . If you did not find any wire terminals touching body at the tail lights and don't see any wires pinched close by , the short would have to be between the fuse and switch. That would mean it is likely the internal contacts in the switch are grounding to the transmission which is grounded to chassis. Understanding your difficulty reaching the switch which prompted to remove the skid plate. Got to be a better way . The only way I'm familiar with is to remove the floor access like you were removing the shift tower . But that involves seats and rug removal as well as console. Just for a switch. No wonder you opted to drop the skid plate . Skid plate is heavy , the seats , console and rug are the lesser of two evils. Just a shame you cannot easily access the switch plug to try a different test without grounding the switch.
I got to the wire on the switch that went to the backup lights and sniped it. There was two wires,one, black and white, the other was purple. The black and white one went to the lights,that I sniped. So no problem with the switch, thanks you saved me 75+ dollars. Now to rewire or find the actual problem, which seems to me it has to do with one of the lights in the back.It may be the switch. Can you disconnect the wires to the reverse lights at the switch? Then try. If it blows a fuse , the problem is the switch. Removing the bulb only shows it is not a bulb issue. With the switch open and a short anywhere from the switch to the light you will not blow a fuse until the switch is closed.
Don't discount the socket itself. I added these and see much better behind the jeep.![]()
