Bullet3600
Well in the last week I've replaced the Head gasket on my 4.0, Starter, Oil pan, Rear Main seal, Transmission mount, Emissions harness, and exhaust. Damn I hope i'm done for awhile. The rear main seal took about 1 1/2 hrs to do and not very difficult at all, remove the main bearing cap 11/16 socket remove the bottom half from the cap, the use a small punch to drive the upper half out enough to grab with needle nose pliers, install the bottom half in the cap and use some form a gasket on the edges, the cover the upper half in liquid soap and slide into the top and reinstall the main bearing cap. Then install the oil pan and torque converter cover.......Bullet[addsig]
