Correct caster angle
freebird2
So I've got some front adj uppers in and I'd like to know the correct caster angle that I can set them to. Got stock uppers right now and it is 7.6 ish on both sides with 33's seems to be doing just fine. Should I go down to 6 degrees or even more?:shades:
I'd keep it around 6º-7º unless you get vibes, then you may have to compromise a little in caster to improve the pinion angle.
