D44 front with Vacuum disco
Bounty__Hunter
Super Moderator
Finally took the cover off the D44 I'll be putting in the front of my YJ. It's from a late model Wagoneer, driver's side diff and vacuum disconnect. I purposely sought out the vacuum disconnect because I'll be running a spool (or lincoln locker again) and it'll be nice to still be able to disconnect one axleshaft when in 4wd. Poor man's selectable locker if you will. This axle disconnects the driver's side shaft, where the D30 disconnects the pass. side shaft. There's actually less to the disconnect than on the D30.
oh boy... i know you have your selectable vacuum system... but if you were to go cable operated... that looks like quite a simple design... i like it
Definatly a cable will work No problem!! Screw the vacuum! This also gets me worked up about my future adventures into the junk yard for axles!!!
Spent my alxe money on a big screan TV for super bowl if you don't recall.
