Do I have a axle problem?
griff
RE: Re: RE: Re: RE: Keep The Smog Stuff Or Not
This mourning I pushed the chassis out to pressure wash and it won't roll back in. I thought it was the transmission so I pull the drive shaft but no luck. The passenger side rear tire won't turn forward. I've never messed with rears before so I don't know alot about them. It was in driving condition before it torn down but the rear hasn't been touched. Can I get to move freely? Thanks again. Griff.
Do a quick check and see if anything has goten into the brack caliper/drum.
While your at it lifting with a floor jack spining the tires will tell you.
if it is in your gears dont worry just yet and pop the diff cover and visual check the ring and pinon. Any real problems will be very obvious here.
