i have an 01 TJ and my front driveshaft rattles like hell i believe its mostly coming from the yoke but i want to replace the whole thing ... is there any other jeep front shaft that can replace it ? like an XJ shaft ???
no already replaced the front U joint thought that was it too .. old one wasnt even bad ... the slack is coming from the slip yoke/shaft right where they meet at the splines... but i've cleaned them both all the splines/grooves are great and when i greased it up really good it stopped the noise for a few days but you can move it considerably and hear it chatter at low speeds ... i had ment to pull it last month but never got around to it .. i have friday off from work so i'll go ahead and yank it out while i try to dig up a replacement shaft... i know that the vibration has cause the front pinon seal to leak like craZy
