dennisonwj
I have a 1988 Wrangler Laredo with the 4.2L and an AX-15 manual transmission. It has the original distributor, factory air conditioning (I KNOW, I did not order it), etc. It also has a Weber 34 DGEC carburator, the Carter is GONE.
I would like to remove the damned ECM and make this Jeep what it should ALWAYS be, mechanical. I was reading that a Nutter Bypass will help me achieve this goal. I live in the National Fascist State of Maryland, but the verhicle is Historically registered and emissions is NOT HAPPENING.
Now the questions fellow Jeepsters.
1) If I do a Nutter Bypass with the above setup, can I REMOVE the ECM and all the wires that are attached to it. Or does it do other things that would require it to be still installed? The Weber does have an electric choke, but I think the ECM is out of that equation. I ask this because it is a nightmare under my dash and it will take real commitment to take apart the dash to unmount it and remove it.
2) After a Nutter, what vacuum tubes DO I NEED TO KEEP, I want to remove and plug all unneeded vacuum hoses, it is a mess in there.
3) After Nutter, I want to also remove the CTO and plug the hole in the block. Has anyone done this, and what do you use for the plug?
		 ! If you already have the Weber and historic tags, you can do away with all that stuff. If you upgrade to a HEI ignition, we can clean up your engine bay all together.
