Fuel Guage Woes...
erhild
Heya...
Been having a problem with my gas guage/fuel delivery...
My fuel guage will read WAY over Full occasionally... Whan this condition occurs, I can't start the Jeep and/or it will die from what feels like fuel starvation... Once the fuel guage returns to a normal position, it'll start rigt up and carry on like nothing has happened... I am thinking it is a bad ground or loose connection someplace... Anyone else run into this problem???
BTW, it's a 91 YJ 4-banger...
Thanx Mucho[addsig]
1045262
Does it do it after it has been filled up?Or does it do it with 1/4 full tank?[addsig]
1045267
Just pretty much happens whenever... Did you have a thought as to why it would happen after fill up or 1/4 tank???
I did mash the tank about 1 1/2 years ago on a 4-wheeling adventure and since then I have been having a problem with my float hanging on the fuel pump tub...
One other thing i noticed today at lunch: My guage tends to swing about wildly... one moment I'll have 1/4 tank the next i'll have 3/4 tank... It just seems to me elecricity is not getting to the fuel pump and shutting it off...
I think I read somewhere that a bad ground will make the guage read over full and a bad hot wire will make it read empty (or something like that)... Maybe here is where I read it... =)[addsig]
1045331
Ok, figured it out...
About 3 weeks ago, took my Jeep® to the dealer for recall work (parking brake assembly)... It seems that whenever I set the parking brake, it is pinching a wire and causing a ground...
Needless to say, I'll be taking the Jeep® in this afternoon and raising holy hell...
Thanx for the support, great website and msg board...[addsig]
