Gas mileage from a 4.0, what do you get?
97teejay
Newbie to the site and to the Jeep world so i wanted to find out what most people are getting gas mileage wise out of their 4.0 In-line six to help find out if i have a bigger problem on my hands.
My 97 TJ is a mod'd a little which i know will affect those numbers but after a full tune and a K&N FIPK i'm still seeing the 10-12 mark which seems low to me.
Here are my specs
1997 TJ Wrangler Daily Driver but may turn into just a trail rig
4.0L 243Cubes (is this the high output 4.0L?)
K&N FIPK with a Fresh tune on it (Wires, Plugs, Cap & Rotor)
33x10.50
3.5 Rubicon Lift
Rubicon Slip Yoke Eliminator
Any imput or tips would be much appreciated, exhaust is next to help it breathe and sound a little better. Any suggestions there would be great.
Thanks!!! :mrgreen:
I'm pushing 33x12.50's getting 16-17mpg. I'm geared down at 4.11 though.
That's a pretty big difference, if you were geared down. Wouldn't you get even less miles per gallon? (higher RPM at lower speed) I have a fealing that something is not right.
Thanks for the imput
I've got 31's and 3:73 gears and get 14-15 city.
Have you corrected your speedometer since you put the bigger tires? If the speed is off that would throw off the mileage.
Do you have a manual or auto? That makes a big difference. The gov doesn't have info for a 97 online, but here are the gas mileage stats for a 1998 Jeep Wrangler:
Engine & Trans | City | Highway | Annual Cost
4 cyl, 2.5 L, Manual| 16 city | 18 hwy | $3343
6 cyl, 4.0 L, Manual| 15 city | 19 hwy | $3553
4 cyl, 2.5 L, Automatic| 15 city | 17 hwy | $3553
6 cyl, 4.0 L, Automatic| 13 city | 16 hwy | $4059
* Based on 45% highway driving, 55% city driving, 15000 annual miles and the price of fuel used by the vehicle.
I personally get 13.6 MPG
Date | MPG
10-Nov | 13.92927176
15-Nov | 15.72286013
20-Nov | 14.98198369
23-Nov | 15.28729573
30-Nov | 14.15187054
7-Dec | 13.7106826
17-Dec | 13.51619956
24-Dec | 13.94557823
30-Dec | 12.51727845
6-Jan | 14.49840713
11-Jan | 14.20560748
11-Jan | 18.11965812
11-Jan | 14.30948419
20-Jan | 16.30434783
25-Jan | 13.96172444
3-Feb | 13.65649606
12-Feb | 14.07641482
15-Feb | 14.00147384
22-Feb | 13.91663796
29-Feb | 13.07989691
3-Mar | 13.18565401
13-Mar | 15.91686398
23-Mar | 13.0560603
4-Apr | 14.2373747
13-Apr | 12.8758087
22-Apr | 13.11299926
27-Apr | 13.49838678
South's right about the speedo. If you put on larger tires, you'll travel farther with every revolution, and your speedo will report you going slower than you really are. You'll also show less miles on the odometer.
Yeah put in a speedometer gear from quadratec and verified it with a gps. It's dead on. Most, but not all, of those miles are interstate. I drive from Murfreesboro to Knoxville for college. I checked again yesterday. At 80mph I got 15mpg and I drove 70 the whole way home but haven't filled back up to check again.
Thanks for all your info guys! It makes me feel a little better about it.
I just learned on the way home that my speedo is off (the city cops set up one of those speed trap signs). The previous owner put the lift and tires on then he sold it.
Terry, thanks for the great info. It is a 5 speed manual.
The gear doesn't look too technical to install, and thanks for the tip to the quadratec site.
The only thing i can't figure out for sure on is what gears do i have to determine which speedo gear to get. i'm 99% sure they are stock. But i've read that they could be 3.07 or 3.55 gears from the factory when i do a search on the net. Any way to tell for sure or do i need to do some digging?
The quadratec site gives me this info which helps a lot
Protect your Jeep while rock crawling with side rocker panel guards & skid plates from Skid Row Automotive, Body Armor, Rugged Ridge, Olympic 4X4 Products & Warn. - Quadratec
thanks again for your time everybody!
The speedometer gear takes a whole ten minutes to change. My searching skills fail me now but there has been a thread about where you can put your vin number in and you'll get an e-mail with everything that jeep came with from the factory. There's also a tag on your differential, mine was on the front axle before I broke it off, that has the gearing stamped onto it. Or you could always jack the jeep up and do it the old fashioned way turning a tire and counting the revolutions of the tire vs revolutions of the driveshaft.
wrangler93, thanks for all the insite...
That site would be cool if anybody comes across it, post up the link.
Sounds like a simple DIY for the speedo gear so i'm on a mission to figure out what gears i have so i can get that speedo gear ordered up. I will check for that tag tomarrow morning, i'm done for the night. Too much parting memorial day weekend.
later!
Finally Found the tags, 3.07 gears stock, should i think about re-gearing with 33 12.5's?? This is going to be a in-town commuter / trail rig. but i would like to still take it on the freeway to get the trail..
There are a crap load of options, let me know what works for you.
THanks!
Last time I checked my 4.0L YJ it was roughly 17 mpg. This is with a 3 speed auto and 31" mudders. This is 70% highway.
City driving is really bad, I never checked it but the fuel goes real quick in stop and go driving.
THanks!
For ease of installation, consider a set of used axles from a 2.5L 5spd TJ, they'll be 4.10 gears and bolt right in. You can usually find them for $400 a pair or less.
thanks for the info!! I think for now i'm going to leave the gears alone and see how they pan out for me.
The only problem you will have with 3.07 are no power going up in the mountains. With 4.10 or 3.55 you will have more power climbing mountain's or steep hills on the interstate
I have a stock (except for high flow air filter in the factory air box) 2004 Rubicon automatic and I get right around 14-15.5 no matter if it's city or highway.
I wish I could get a squeak more mileage out of it. 16-17 and I'd be happy.
by the way it sounds. . . I think you can get it. you already get 14-15 its now easy for you to get 16-17.
I have a 91 YJ 4.0 litre 5spd running 31's tb spacer and cold air pkg.around the city 16-17 mpg.No lead footing or speeding.Having fun drops to 13-14 mpg.good luck....
The 4.10's in the Rub are just going to be too much for me to overcome to get better mileage. At some point I'll have a go at the Borla exhaust and see what happens. For time time being I'll just endure :D
So does this also apply for digital???
I have 4:56 gears pushing 35's automatic
air intake tbs and glasspack and i get 16/17 mpg. ...but if my odo is wrong i guess my calculations are wrong????
My speedo is about 15-20 mph off all the way around. but I put on an aftermarket gauge face and had to remove the needes in doing so ..
