An engine mount is in the way of an oil pan bolt on the passenger side. How can I take the mount off and drop the pan at the same time? How can I hold up the engine with both off?
I would use an engne hoist. Pick the motor just like you were going to pull it but only lift it up as far as you have to get to the bolt. You may need to disconect a few things on the motor too.
