Walked into garage to find the headlights on the jeep on (TJ 2000). smell of burnt plastic and found the following issues. turn/dimmer switch in steeing column melted there are two rolls of terminals one a (11)pin connector and a larger (4) pin connector, the (4) pin connector is melted pretty bad, the (2) terminals nearest the curved part or inside edge of the switch are toast, I disconnected the battery and the disconnected this unit from the steering wheel the two pins that are toast are colored coded from the connector as Green/white and Red (these 2 have the switch melted, also these two wires have 12 volts on them is this normal??) the other two Green and Purple/white are fine. After disconnecting and reviewing the wiring going to the headlights I found this wiring to be questionable and maybe it has shorted and caused my issue??, has anyone had this issue??. basically I walked into the garage and my headlights were ON, everything else on the JEEP was off including the head light switch I hate electrical problems
:? :bomb:
