Utah_jeepster said:The crank position sensor is a known problem of wigging out without throwing a code. I had it do it twice on my 01 TJ, without throwing a code.
Shephard10 said:I just recently had a problem like that. Check the temp you're runnin next Tim it kills.
35's and a Lift Kit. How Stuck can ya Get?
Shephard10 said:As soon as mine would get above 210* it killed. I'm usually runnin right below.
Anyway... If it's above the normal temp. it might just be overheated, that was my problem.
I just bought a taurus fan and plan on doin the electric fan swap whenever that comes in.
I drove it around today. Didn't temp didnt go near 200 degrees. It didn't overheat. I can't explain what happen. I was also near empty but don't think it was a factor
JPNinPA said:Did it happen or did it not happen today?
