Jeep Wrangler TJ 8.8 Axle Swap Kit
Dan Fredrickson
This weld-on bracket set let's you adapt the popular Ford 8.8" rear end to the stock suspension mounts in your TJ! Includes all the brackets to mount your existing upper and lower control arms, track bar(Panhard), coil springs, shocks, and swaybar.
This set is designed to fit the 3.25" tube diameter of the 8.8 but can be used for any tube diameter from 3"-3.5" with a few adjustments.
