I understand. It can get a little pricey to lengthen a driveshaft as it requires a new tube, and price varies depending on the price of steel. Take a look at other YJ's with different drivetrains as the rear driveshafts varied across the Wrangler model.
I've got some YJ driveshafts and may have what you need. Install your stock driveshaft and tell me how much silver is exposed on the slipyoke where you can tell it is pulled out of the transfer case tailhousing. Also measure your driveshaft 'center of ujoint' to 'center of ujoint'.
Also keep in mind that the rear axle pinion should not be pointing at the transfer case output, it should be down from there, parallel with the transfer case output.
