Mega Short SYE Slip Yoke Eliminator Kits w Speed Sensor NP231 87-06 Wranglers
Baseline 4x4
This kit is a MUST if you installed a 2" or taller suspension lift in your 1987-2006 Jeep« Wrangler (not needed for body lifted Jeeps«). The kit fits all newer production NP 231 transfer cases (1987- up). A Slip Yoke Eliminator Kit (SYE) will eliminate the need to drop your transfer case in order to avoid drive train vibrations that are caused by taller suspension lift. The purpose of this kit is to replace the slip yoke portion of the NP 231 with a fixed yoke and CV-style drive shaft assembly. This is the most complete and strongest kit available. The Mega Short SYE (18676.72) is designed to be used in the same lift applications as the other standard SYE kit (2" and up). The main advantage to the new Mega Short SYE kit is that it allows for a much longer drive shaft to be used (additional 3"). This reduces the angle of the dive shaft and in turn improved bearing and u-joint life, reduces driveline vibrations caused by lifted Jeeps running short drive shafts. It also has a shorter and stronger main shaft design.
Fits: 87-95 Jeep YJ Wranglers
97-06 Jeep TJ Wranglers
84-01 Jeep XJ Cherokees
18676.72 - Rugged Ridge Mega Short Sye Slip Yoke Eliminator Kit Np231j
16592.06 - Rugged Ridge Rear Cv Drive Shaft TJ Wrangler 97-06 3.5"-06" Lift, For Mega Short Slip Yoke Eliminator #18676.72
We also have the standard SYE and CV Driveshafts available.
18676.60 - Slip Yoke Eliminator Kit, Np231
16592.01 - CV Rear Driveshaft, 1-3 in of Lift, 87-93 YJ Wrangler
16592.02 - CV Rear Driveshaft, 4 in of Lift, 87-93 YJ Wrangler
16592.03 - CV Rear Driveshaft, 1-3 in of Lift, 94-95 Jeep YJ Wrangler
16592.04 - CV Rear Driveshaft, 4 in of Lift, 94-95 Jeep YJ Wrangler
16592.05 - CV Rear Driveshaft, 2-5 in of Lift, 97-06 Jeep TJ Wrangler
Free Shipping on all orders over $199!
Tony Feichter
Jeep Parts and Accessories
Baseline 4x4 Outfitters
1-866-554-5946 Toll Free!
260-636-7565
www.baseline4x4.com Jeep Parts and Accessories
TonyFeichter@baseline4x4.com
Standard Slip Yoke Eliminator Kits on Sale at Baseline 4x4 Outfitters
