Alright, got the carb and I even put a kit in it this afternoon (much easier than I expected, but we'll see if it works.....). It's a 2150 off an 80 ford pickup. It's got a port coming out of the back at the base on drivers side (large), a port coming out of the top in the front middle (med), a port on the power valve, a port to the right of the driver's side idle adjustment screw (if you're looking at the carb from the front), and a small port coming out of the passenger side of the carb in front of the choke (also on the base), and one more coming out of the bottom of the air horn on the back. I've got vacuum advance from dist to hook up and the two vacuum hoses off the valve cover. What goes where and is there anything else I need to hook up. Also have a threaded part on the back of the choke assembly. What goes there? The jeep currently has a manual choke on the BBD and I want the electric choke on the 2150 to work. Anybody know where to run the wire? Thanks for any help!
