whats up guys and gals. i was changing the brake fluid yesterday on my 91 yj. i started at passenger rear, no problem fluid came out fine. went to drivers rear opened bleeder and nothing came out. so i went to passenger front and i got good clean fluid comming out fine there. then to the front drivers and nothing there? so the passenger front and rear bleed fine. but nothing front and rear on drivers side. it dos not really pull when braking or anything. and i have no helper to pump the pedal and see if i can clear the clog.
I was wonder if there is a clog somewere that would keep both drivers side from getting fluid or is it just by change that they both happen to be clogged? brakes seem fine. i should mention my method of changing brake fluid so you know i was just placing a clear hose on the bleeder and cracking them open and whatching them till clean fluid came thru, and keep the master full i did see some nice black chunks and dark fluid. thanks whats the problem?
