Well, I finally did it.
I put a rebuilt 258 in my 87' about a month ago. So far everything is fine so far except for a small oil leak. It would'nt bother me if it weren't for the fact that it gets on the exhaust. My first suspect was the rear main but i just replaced it with the rebuild while i had the engine out. My next suspect was the oil pan gasket which is still a good possibility but i noticed oil on the passenger side of the block by the coil and dist and that got me to a wondering, i know the dist is supposed to have a round gasket at the base which is never there in the first place or too torn up to reuse and just gets overlooked on the install. This engine was no different and didnt have a dist gasket, but could this be the oil leak that is blowing back the side of the engine? The oil only leaks when the engine is running. Thanks guys for any help.
od
od
