Quick 2.5 question
Doug McBride
My wife's Jeep (97) TJ has started to knock so, I have located a good bottom end(95).
My question..... will everything (head,intake/exhaust, etc.) from the 97 2.5, bolt together the same with the 95 2.5 block?
I don't want to mickey mouse or buy anything extra.....
Thanks
Did you ever get an answer?
I did some research, and the only thing I could find was this:
I went the opposite direction with my Jeep 97 engine into a 95 jeep. Sharpxmen is right, you wan to use your current distributor, coil, and sensors, ( oil pressure and temp). I needed to use the old engine mounts also, as they were different. The old engine's drain plug was on the back of the oil pan and the current one is on the side. Other the that, I did not see enough difference to change them. good luck
