Pardon me while I reply to your post, and no, it's not jealousy, or Rubi envy :roll:
phall92139 said:
I own a '03 Rubicon and have been extremely pleased. I know there are a lot of Jeepers out there that enjoy flaming Rubi owners (and maybe alot of them deserve it if they bought a Rubi to pound pavement with) but I also know there's a lot of jealousy involved. It is truly an amazing stock vehicle and will satisfy the needs of many off-roaders but the adage that "real Jeeps aren't bought, their built," still holds true with the Rubi as well. Albeit they have a great head start as their delivered, you'll still want to add aftermarket bumpers, tire carrier, winch, skid plates for the differentials, steering box and better skids for the belly and gas tank. You'll probably end up doing some sort of lift and larger tires, convert the factory roll bar to a six-point cage, better air intake and exhaust, etc. However, even with all of this, you will still come ahead because you've already got a better transmission, transfer case, front and rear lockers, and front and rear Dana 44s.
Okay, you've got the same transfer case but with 4:1 gearing and no slipyoke. You've got the ring&pinions and shafts of a real D44, yet the axle tubes are the same wall thickness as the weak D35. I don't understand how you think the Rubi has a better transmission than another '03 or '04 4.0L TJ.
This leaves you with the advantage of lower axle gearing and front and rear lockers. Is that worth $6000 to $10,000 more than the X model?
phall92139 said:
In my case, while I'd love to build a Jeep from the ground up but based on past experience, the money to do this just never seems to be available.
Money, you spent $26K to $30K on average :roll: If you're going to add "aftermarket bumpers, tire carrier, winch, skid plates for the differentials, steering box and better skids for the belly and gas tank. You'll probably end up doing some sort of lift and larger tires, convert the factory roll bar to a six-point cage, better air intake and exhaust, etc." to it, you might as well get a base 4.0L TJ and install some real D44's.
Okay, stepping down from the soapbox. The Rubi is a great jeep, best off-the-shelf package ever offered. And it does what a lot of people want it to do, and unfortunately for some, that's restricted to the Mall.
I can understand not having the time, experience, or shop to build a comparable jeep, but not having the money? :lol:
