Utah_jeepster
Super Moderator
Ok I am tracking down a small whobble I get from the steering wheel when I hit small bumps in the road.
First the details...2001 TJ with 4 inch lift long arm. 35' tires at full pressure/ rims are ok with no cracks. Just been balanced and rotated less than a month ago.
Checked the wheel bearings/axle shafts for play (none).
The U-Joints look fine with no seperation or gaps(did not pull them apart to see).
I do have a crushed upper end track bar boot and can move the bar fowards and backwards some. I think I need to replace the upper and lower bushings on the track bar and that might be where my problem is.
Yes ? no? suggestions?
