Speedometer/Gas/Milage out
rawFrenzy
If anyone can point me in the right direction I would be much appreciative.
I have a 98 Cherokee and am having issues with some components no longer functioning.
Here is a list of what no longer works (all happened at once):
-Speedometer (sits at 0)
-Gas Gauge (sits at empty)
-Milage/Tripometer (no power, no display)
-Pilot Light (doesn't illuminate when door opens or when turned on manually)
-Headlight Warning Buzzer (doesn't sound when lights left on)
There may be more but I haven't noticed anything else.
I did open the panel under the steering wheel and was installing a new car stereo (and routing a bluetooth mic to sit on the steering wheel). I don't remember bumping any wiring or anything and I've since checked and do not see anything loose. This has all happened since I was in there. I now have no stereo installed until I figure this out.
Noteworthy that everything else on the dash works, shift indicator light, fuel door open, etc.
Any pointers?
Thanks anyone!
-Peter
Yes I did. They all seem to be fine. Although in the manual I didn't see any fuses listed for any of the components that went out.
Have you tried to remove what you just installed and trying again? How did you install it, splice into another wire, which one?
