8177
While  searching for info on leaf springs I kept running into replies to posts suggesting body bushings. Ok I'll admit this is a new one to me. I'm guessing if you wanted to add tires to big to fit under your fenderwells you could raise your body up a bit with the bushings. What if you didn't want to lift the body, but wanted to just replace the stock bushings. i have only actually looked at the rear  corner bushings and they look ok, But looks can be deceiving. If I wanted to check the other bushings out are there certain ones that deteriorate faster than the rest. Would it be prudent to spend 50 or 60 bucks just to have piece of mind that they are new?
Now on the leaf springs it seems that you can buy the kits that give you a lift cheaper than some of the stock sized leaf kits. How big of a lift can you add before you need to start lengthening the drive shafts and changing the angle of the transfer case and all that other tweeking associated with lifting the jeep. Honestly other than the fact that my front springs are flat and the rear ones are iffy on their condition I dont think I need a lift, but if 2 inches does not need any other suspension changes I wouldn't mind adding it.
Man its tough being a new owner of a 32 year old vehicle that the previous owners just let go.
Jim
Jim
