weldiniron718
I have an 87' YJ that is stripped down. The NP231 transfer case has a bad grinding feeling when turning the front driveshaft by hand. Either I can rebuild this transfer case (is it worth it?) or I can upgrade to a new-used transfercase. What will fit my manual transmission or should I rebuild the NP231? I would like to keep the cost down. The jeep has a straight six, 4.10 gears w/lockers front and rear. I am in the process of doing a SOA and reinforcing the frame where neccessary. I need the Transfer case in so I can line up my pinion angle. I'm new to jeeps so any help would be appreciated.
Thanks, Jonathan
Thanks, Jonathan
