Yes. With the Jeep running and tires chocked, pull the 2 black vacuum lines from the front axle. Have a trusted friend shift the transfer case between 2wd and 4wd while you feel for strong equal vacuum alternating between the 2 lines.
If you have strong alternating vacuum, remove the disconnect housing from the front axle (4 bolts). Make sure the shift fork moves back and forth easily.
