Brake adjustment
wm69
I just got my master cyl and booster replaced on my 85 CJ and it seems like the pedal goes farther than it used to. The thing stops ok but the pedal seems to get closer to the floor than I'm really comfortable with. Any way to adjust the pedal? Thanks
might be a linkage you can tighten or somthing no?
Might still have an air bubble in the line someplace, maybe just to one wheel allowing for the stopping power but long brake pedal travel.
Bleed them break again and maybe even again in a day or two till you are way sure the air is out of the system. tug
thought they might need blleeding again; hope that's not the case as the guy that did it is not only a buddy but the best mechanic I've found around here. I'll try it and if that doesn't work I'll take it back to him and see what he says. Thanks for the responses
