motor mount noise after lift
nkdskls1978
RE: Transmission cooling tech.
just put on R.C. 4" lift with 2" tc drop and now driver's side engine mount is making a lot of noise. seems tilted toward the rear and the metal is rubbing inside. how can I fix this?
can I take out the mount and grind down the metal lip?
or should I adjust the TC angle somehow?
i guess that u allready figured out that the motor mounts are grinding against each other, cuz when u droped the t-case it pulled the driveline back, when this happened to mine it just wore it self down and the noise went away. i dont know it its gunna weeken the mount if u actually take it out and grind it, but its worth a shot...
