    Dash Gauges Not Working - Not Fuse
    98 Jeep Wrangler Sport
    The other day when I used my signals they seemed to click real fast. I shut it off, and then signaled again....all was back to normal.
    HOWEVER....just after that (I am not sure if the problem is related or if two separate problems) I noticed than no gauges on my dash were working except for the oil pressure.
    No Speedometer, Fuel....etc.
    I changed the Fuse (Space 10 / 10Amp)….even though it did not look blown.
    That didn’t work so then I pulled every single fuse and looked them over…..none blown.
    Any idea why the gauges would not be working?
    Any idea why my signal lights would be clicking so fast…then normal again?
    Thanks!
    Re: Dash Gauges Not Working - Not Fuse
    pull the gauge cluster and make sure that the connection between the cluster and pannel is clean and free from corrosion.
    It used to be a jeep Thing,
    But all that stuff broke
    -Johnny-
  1. Gauges Not Working
    By tripz in forum Wrangler and CJ
    Last Post: 06-25-2010, 03:47 PM
  2. '94 jeep cherokee Dash not working
    By sonedays in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 11-28-2008, 12:36 PM
  3. gauges quit working?
    By Mxpx182lit in forum Wrangler and CJ
    Last Post: 02-22-2005, 05:04 PM
  4. I have working YJ gauges now! Even the gas gauge!
    By Jeepr89 in forum General Chat
  5. 1998 TJ Dash Swap - Will a 2000/2001 dash fit in my '98?
    By 83CJ701DakRT in forum Wrangler and CJ
