rotedog
I was cranking my jeep and something broke causing my key to turn freely forwards and backwards and will not turn the motor over. I thought it was just a matter of replacing the keyed cylinder but now I think maybe it's something to do with the mechanism that causes your key to disengage the starter when you release the key after cranking. Has anyone had this problem? Need some help on how to fix this problem? Should I just bypass the switch and add some sort of toggle switch for cranking?
