1. no dome light or radio
    I have checked all fuses changed IOD fuse under hood still nothing . I am getting 24 at plug for radio & 23.6 at amp. Any suggestions
    Oct 2011
    Millersburg, Oh
    449
    Did the wire to the speakers fry or get cut?
    Just
    Empty
    Every
    Pocket
    Feb 2012
    Cincinnati, Ohio
    1,993
    Re: no dome light or radio
    Most stereos nowa days have a fuse on the back of the unit. Try to check there, mine got wet once and blew that fuse
    24 and 23 what? Volts? Sent from my iPad using Jeepz
    Are they both fed from the same fuse?
    I think you need to recheck your meter readings.
    Unless you have a 24 volt system, maybe you didn't make good connection with your meter probes.
    Place the meter on resistance, put one lead on the small battery post, the other on the case of the amp, meter should read somewhere around .3 ohms.
    If that is close, put the meter on DV voltage scale, connect red lead to large battery post, put black probe on the power wire at the amp. If you read voltage you have a problem on the power side. If no voltage is there then Life is good. While you are still connected to the battery, put the probe on the amp remote terminal, If you read voltage then it is in the remote circuit.
    I am suspecting the light and stereo are either unrelated, or it will be a power problem.
    Good luck.
    It would also help to know what year and model jeep you have..
  1. no wipers or radio
    By sawmill in forum Wrangler and CJ
    Last Post: 10-18-2011, 12:22 PM
  2. Dome light issues
    By bmsgolf in forum Wrangler and CJ
    Last Post: 11-13-2003, 11:22 PM
  3. looking for jeep decal for 3rd brake light or jeep light
    By sparkyshotrods25 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 10-22-2003, 06:16 PM
  4. No brake lights
    By berettajeep in forum Cherokee, Commander, Wagoneer and Liberty
  5. I have no fog lights or new wheels but
    By XJNick in forum Cherokee, Commander, Wagoneer and Liberty
