Joopin
Super Moderator
I have delayed my SOA project once again when I decided I wanted 35s under my YJ. This started my hunt for a Dana 44 rear to put in place of my D35 since I heard that the D35 breaks often when running 35 inch tires.
I have been researching the D44 swap, along with other axle swaps (8.8, 9", etc.) and the D44 applealed to me because of the WMS length is wider than 60 rather than narrower like others.
I also planned on just swapping out the rear axle and not the front since my research led me to believe that the D30 can handle 35s and it will be MUCH less money to spend.
So now that I found the type of D44 I wanted out of a Wagoneer, I came to find out today that the lug pattern is different (5 on 6) than the D35 or D30 (5 on 4). I don't want to run around with different lug patterns in case I get a flat, so that means I have to either switch the D44 over to the 5 on 4 or get a matching front axle with the same lug pattern. BOTH are projects I didn't plan on and don't really have the time or money to do.
Now I ask myself, all this just to run 35" tires? 33s will most likely look good under an SOA lift. Or could I run the 35s anyways on the stock axles and risk it? Do they only break when offroading? Offroad to street right now for my YJ is about 20:80... I plan on evening that out some but who knows when.
Sorry about the long post, just venting and wondering if anyones has any thoughts on my dilemma. I seem to be making things harder for myself here!
