99 jeep cherokee stalled out and wont start it does turn over
Start with fuses. Most likely itl be something with ur fuel system or spark. You can check if its fuel by spraying some ether down the throttle body
Most likely it's the crankshaft position sensor if it's turning over but not firing. Located top of bell housing behind engine block on drive side. This sensor won't toss a code when they go bad
