1. 2007 Liberty Limited - IOD fuse location / ETC light is on and car won't start
    Thanks so much - I've gotten really great help here before, so!
    I've been disconnecting my battery periodically over the years to turn the check engine light off - also for a year or so, the 3 lights ABS, ESP, and Air bag lights come on intermittently when driving but they usually shut off by themselves, and the car drives 100 percent, so I haven't worried about that. Today I disconnected the battery twice in a row to see if it would shut of the 3 lights, and when I tried to start it, it wouldn't turn over and the ETC light came and stayed on (never seen it before).
    My battery is charged up, too. I've seen a few threads online that referenced pulling the IOD switch for about 30 seconds to re-set the security (?) system which in turn solved the ETC light and starting issue. Could someone help me locate that IOD fuse? I can't seem to find that info anywhere. Also, I saw a few people mention a grounding problem that caused this issue that was fixed by adding an additional ground wire to the negative battery terminal.
    Any suggestions, and the location of the IOD fuse would be greatly appreciated. If it even has an IOD fuse!
    I've disconnected the battery numerous times for various lengths of time and still nothing.
    Thank you -
    Pauly B
    Dec 1999
    Virginia Beach VA
    8,038
    Re: 2007 Liberty Limited - IOD fuse location / ETC light is on and car won't start
    Pauly,
    Is your Jeep throwing any codes? If so, what are they?
    My 2005 Wrangler Build Thread
    Feb 2009
    Dayton Ohio Area
    5,389
    Inside fuse box #13. & #14 are the BCM and pDC for SKIM
    # 32 sentry key
    #33 Immobilizer SKIM
    Under the hood #26 auto shutdown
    Jeep Liberty (2007) – fuse box diagram - Auto Genius
  1. 2002 jeep liberty o2 sensor location
    By fedexsdd in forum Washington Jeep Forum
    Last Post: 02-03-2015, 12:47 PM
  2. NEED fuse location #
    By 54cj3b in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 04-13-2013, 12:56 PM
  3. 2007 Jeep Liberty fuse blowing
    By 4door jeeps in forum Jeep Electronics and Audio
    Last Post: 07-29-2009, 07:31 AM
  4. Fuse location
    By hillbillyman06 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 03-13-2007, 10:16 AM
  5. location of fuse for turn signals on 96 Cherokee
    By MudderChuck in forum Cherokee, Commander, Wagoneer and Liberty
Tags for this Thread
