1. 2005 Grand Cherokee Hard to fill fuel tank
    Looking for some guidance. We have a 2005 Grand Cherokee Laredo that builds up prssure in teh fuel system. When we pull up to fill it and remove the fuel cap, it releases a lot of pressure. It is hard to keep the fuel pump running because it keeps tripping off, while filling. I've replaced the fuel carbon canister, pulled the tank and blew air thru all the lines. I've also replace the evap purge valve. Any ideas would be appreciated. Thank you./
    Re: 2005 Grand Cherokee Hard to fill fuel tank
    maybe try a try a new gas cap. I've had a few vehicles that you needed to pump gas in a little slower to avoid tripping.
    Feb 2009
    Dayton Ohio Area
    5,740
    2005 TJs do this when full. Pukes gas. Some have changed the fill tube and others found the vent tube bent/clogged.
    Being you have lots of pressure it sounds like a vent is not working properly. Are you certain the pressure is positive not a vacuum?
    Hard To Fill Gas - Jeep Cherokee - YouTube
  1. 2005 grand cherokee
    By USAFJEEPR in forum All other Jeep models
    Last Post: 03-05-2013, 12:57 PM
  2. Overheating 2005 Grand Cherokee
    By Cool Ridge Jeep in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 08-29-2010, 08:42 AM
  3. 2005 Grand Cherokee Hemi
    By Joopin in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 12-17-2009, 09:20 AM
  4. Fire above fuel/gasoline tank on Grand Cherokee WJ
    By gregchristos in forum Cherokee, Commander, Wagoneer and Liberty
  5. Fire above fuel/gasoline tank on Grand Cherokee WJ
    By gregchristos in forum General Chat
Tags for this Thread
