Windshield lights wires routing
60mg
I'm looking for ideas on how to route in the wires for windshield mounted lights. Please post some pix. Thanks in advance.
Here is a video on a JK but the idea is the same.
Into the cowl, out to the relay by the battery.. Relay to battery thru a fuse and the switched connection into the cabin by the brake to switch. Switch power to ign circuit fuse behind the glovebox.
60mg said:
I should have probably mentioned that I have a YJ :)
You should still have the cowl opening like the tj's do, but if you don't you can always drill a small hole on both sides and cover it with a rubber piece or maybe some rtv silicone.
