Yj door problems
Jeep4230
Just got a new yj and the passenger door won't open from the inside got the handle off and found the linkage just sitting inside. The door not hooked up so hooked it up and put the door back together and back on the jeep opened two time and linkage fell off again any suggestion
Thanks
Elton
Until you can run down and get of those little plastic linkage pieces in the self help aisle at the local auto parts place, use some safety wire or a zip tie to hold it o
