Thread: Rear axle
    Johny's Avatar
    Johny is offline Junior Member
    May 2017
    5
    Rear axle
    I recently broke and replaced the rear passenger side axle. When I removed the dif cover, the only thing loose in there was the clip. Everything else was intact. The thing is that now it's been put back together I find it will only drive when 4x4 is engaged. Does anyone have any ideas on this?
    k-2's Avatar
    k-2
    k-2 is offline Senior Member
    Apr 2017
    259
    Re: Rear axle
    Before diff removal for rebuild. Could it be ONLY front diff (4x4) is being driven? Spider gears? Pinion?
    Tell model year, engine Transfer case type, rear axel series etc and we an add info
    TerryMason's Avatar
    TerryMason is offline Administrator
    Dec 1999
    Virginia Beach VA
    7,464
    Re: Rear axle
    Welcome to Jeepz.com!
    What year and model of Jeep do you have?
    It sounds to me like you're not getting any power to the rear wheels. I'd open up the rear diff and jack up the rear wheels, and see what happens when you spin the tires. Spinning one tire should spin the other, like this (about a minute in):
    Johny's Avatar
    May 2017
    5
    Re: Rear axle
    It's a 92 4.0 6 cyl. It definitely drove in 2 wheel drive before the axle broke. When I initially broke the axle, I could only get it to run after I engaged the 4x4.
    Johny's Avatar
    May 2017
    5
    Re: Rear axle
    Solved
    TerryMason's Avatar
    Dec 1999
    Virginia Beach VA
    7,464
    Re: Rear axle
    What was the problem?
  7. #7
    Johny's Avatar
    May 2017
    5
    Re: Rear axle
    The guy who put the dif back together told me to put it in high and drive it, then put in 2 wheel drive. It worked, apparently because it had been stood a while, he said the fluid had to have time to work. I really don't know, but it works fine now.
  8. #8
    Bounty__Hunter's Avatar
    Nov 2002
    Southern Illinois
    13,323
    Re: Rear axle
    It doesn't work like that. Your issue was mechanical, not fluid related.
  9. #9
    Johny's Avatar
    May 2017
    5
    Re: Rear axle
    Well he was right, it worked and all is well now.
  10. #10
    Knuckles's Avatar
    Knuckles is offline Senior Member
    Dec 2014
    Eastern Idaho
    102
    Re: Rear axle
    Quote Originally Posted by Johny View Post
    It had been stood a while? This thread be not what I understand no way, lol.
  1. Wtb rear axle for 79 cj5 amc 20?
    By blaylock6502 in forum Items for Sale, Trade, or Give Away
    Last Post: 05-09-2016, 11:57 PM
  2. Rear Axle Help
    By Steven Seimer in forum CJ YJ TJ and JK
    Last Post: 07-26-2014, 09:24 PM
  3. Rear Axle
    By Hoyas 011 in forum CJ YJ TJ and JK
    Last Post: 07-14-2009, 02:28 PM
  4. Please Look at your Rear axle if you own a TJ...
    By jeepin916 in forum CJ YJ TJ and JK
    Last Post: 06-12-2008, 11:14 AM
  5. Rear axle
    By jps4jeep in forum CJ YJ TJ and JK
    Last Post: 07-02-2004, 11:50 AM
