2003 jeep wrangler.
The brake dash light will not light. The light and buzzer also do not operate if the jeep is in motion with the e-brake pulled. The ((P)) e-brake light does light up with the onset of key turn and with self dash electrical test. I have replaced the e-brake switch ( old one still was good I tested via continuity test) the grey/blk wire I've traced up to just past shifter area then it gets lost in an bundle.....continuity good. Where does the wire go to? Connector?
i read somewhere that it is part of computer to do to it being involved with the wheel sensors/motion etc.
All other lights and gauges work ( other than I pulled the relay for the fog lights as the multi switch lever wouldn't shut the off....like other have experienced)
No wiring has been altered, no trailer wiring.
Dealer can't explain it.
I would appreciate any help, diagrams and experience to resolve this issue......
thank you.
thank you.
