Page 4 of 5 First ... 2345 Last
  1. #61
    eric m's Avatar
    eric m is offline Senior Member
    Oct 2011
    Millersburg, Oh
    441
    My girlfriend got tired of my mismatched doors and wanted to paint my jeep
    So about $50 bucks worth of paint and supplies later...
    Just
    Empty
    Every
    Pocket
  2. #62
    TerryMason's Avatar
    TerryMason is offline Administrator
    Dec 1999
    Virginia Beach VA
    7,974
    Re: The Cheap Wrangler Build...
    Sounds like you've got a keeper there!
    My 2005 Wrangler Build Thread
  3. #63
    eric m's Avatar
    Oct 2011
    Millersburg, Oh
    441
    Quote Originally Posted by TerryMason View Post
    Yes I do, I'm very lucky.
    Just
    Empty
    Every
    Pocket
  4. #64
    eric m's Avatar
    Oct 2011
    Millersburg, Oh
    441
    I took my jeep to the 2016 4wd hardware jamboree. I don't any pictures and an not sure how to post video but 4wd hardware posted there obsticale course and mud pit video my jeep is on at the 1:30 mark. I'm stoked!
    Just
    Empty
    Every
    Pocket
  5. #65
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    5,079
    Cool.
  6. #66
    TerryMason's Avatar
    Dec 1999
    Virginia Beach VA
    7,974
    Quote Originally Posted by eric m View Post
    I looked on youtube, but didn't see it. If it's a youtube video, just copy the link and past it here.
  7. #67
    JPNinPA's Avatar
    Feb 2009
    Dayton Ohio Area
    5,079
  8. #68
    eric m's Avatar
    Oct 2011
    Millersburg, Oh
    441
    Thanks! I'm not super computer savy, and I'm still using a 3G phone in a 4g world....lol
    Just
    Empty
    Every
    Pocket
  9. #69
    eric m's Avatar
    Oct 2011
    Millersburg, Oh
    441
    I've never liked the back seat in my tj as far as having my son ride back there. There is no neck support and it's not the greatest. I modified a jk back seat and used it with the lower portion of my tj back seat to fix the issue.
    Just
    Empty
    Every
    Pocket
  10. #70
    eric m's Avatar
    Oct 2011
    Millersburg, Oh
    441
    The nice part of this jk to tj seat conversion is I'm only into it $50. It was a bit more labor intensive than if I were to install it in a 03-06 tj as they use the same style latches as the jk.
    Just
    Empty
    Every
    Pocket
  11. #71
    TerryMason's Avatar
    Dec 1999
    Virginia Beach VA
    7,974
    I like that JK back seat - I know what you mean about the neck support. Did you lose the fold and tumble, or can you take the head rests off and still do it?
  12. #72
    eric m's Avatar
    Oct 2011
    Millersburg, Oh
    441
    It will still fold, I will have to remove the headrests tho. I haven't tried the tumble yet as the jk seat is 4" taller than the tj seat, I don't think it will tumble.
    Just
    Empty
    Every
    Pocket
  13. #73
    eric m's Avatar
    Oct 2011
    Millersburg, Oh
    441
    The Cheap Wrangler Build...-img_0453.jpgThe Cheap Wrangler Build...-img_0441.jpgThe Cheap Wrangler Build...-img_0442.jpgThe Cheap Wrangler Build...-img_0445.jpgThe Cheap Wrangler Build...-img_0446.jpgThe Cheap Wrangler Build...-img_0447.jpgThe Cheap Wrangler Build...-img_0450.jpgThe Cheap Wrangler Build...-img_0452.jpgNow to derail my own thread....a couple of months ago I was getting ready to do some exhaust work on my Wrangler when I discovered an un-patchable spot on my frame. This isn't a huge surprise planning to replace the frame come spring, however I wasn't expecting it to get this bad, I had hoped to safely drive the Jeep till I fixed it correctly. When the swap comes I have a couple of plans for the Jeep that I will reveal then. Well finding myself without a vehicle I looked at several and settled on an 2002 Jeep Liberty Renegade, it has 200k but the engine only has 60-70k and it had been decently maintained. It needed a few things from setting (it was a 3rd vehicle for the seller and was only driven occasionally for the last year) I did my customary new vehicle oil change, replaced some frozen brake pin sliders, front drive shaft CV joint, and the electric fan. I have since replaced the worn tires with some 245-75 R16 Goodyear Dura tracs, this is where I found how sagged out the stock suspension was. I did a good amount of reading on the subject and have found that the stock suspension can lose more than 1" of height IN LESS THAN 80,000 MILES! Couple this with the worn shocks and struts and I chose to upgrade. I purchased 2" lift TJM springs from Summit Racing (they are doing away with their product line so all of their products are deeply discounted), I got front HD and rear springs for $160, I bought an G2 diff cover for the 8.25" rear diff while I was there. I ordered some 2" lift shocks for a WJ grand cherokee (Rubicn Express monotubes they are Bilstien 5100's made for Rubicon Express), I also order the recommended TeraFlex bump stops and some Bilstein front struts. I made the rear bumstops from hockey pucks. So far the rear lift is in and I'm hoping to finish the front this week and get it aligned.
    Just
    Empty
    Every
    Pocket
  14. #74
    TerryMason's Avatar
    Dec 1999
    Virginia Beach VA
    7,974
    I was looking at those photo's thinking you had upgraded your Wrangler - new rear axle, new coil overs, etc..
  15. #75
    eric m's Avatar
    Oct 2011
    Millersburg, Oh
    441
    Not quite lol. Just fixing a few issues with my new to me second Jeep.
    Just
    Empty
    Every
    Pocket
  16. #76
    eric m's Avatar
    Oct 2011
    Millersburg, Oh
    441
    Lift is all finished and the Jeep is aligned. I will end up replacing the rear driveshaft U-joint(s) and keep an eye on some of the other older parts but for now this should end my thread derail, lol. For anyone that is curious I will post a part list and rough pricing, in most cases Liberty's are cheaper than Cherokee's or Grand Cherokee's and they aren't bad Jeeps.
    Pricing for 2" lift:
    Bilstien front struts $203 (pair/ Amazon)
    TJM HD front springs $81 (closeout price Summit Racing)
    TJM rear springs $81 (closeout price Summit Racing)
    Rubicon Express Mono Tube shocks (Bilstein 5100's) $175 (pair/4wheel parts)
    TeraFlex front bumpstops $44 (Quadratec)
    4-Hockey pucks $12 M.C. Sports (rear bump stops)
    I ended up adding a few extra but not required items such as new top plates and isolaters for the front struts as I didn't want to reuse the old pieces and I wanted to assemble the front struts to save time on the lift install.The Cheap Wrangler Build...-img_0454.jpgThe Cheap Wrangler Build...-img_0364.jpgThe Cheap Wrangler Build...-img_0458.jpg
    First pic is front lift installed (minus the bumpstop, they are easier to install when the tire is back on and the Jeep is on the ground), second is with new tires before the lift and the final is lift installed.
    Just
    Empty
    Every
    Pocket
  17. #77
    eric m's Avatar
    Oct 2011
    Millersburg, Oh
    441
    Just thought I post another update on the Liberty. I'm still on the lookout for a frame, it looks like next year now but I'm still plugging away at other projects on the TJ getting ready for that time. In the mean time I've been tinkering some, I installed a couple of sets of LED headlights recently and decided I wanted a set for the Liberty. Problem is no one makes them....well I got creative.
    The Cheap Wrangler Build...-img_0616.jpgThe Cheap Wrangler Build...-img_0615.jpgThe Cheap Wrangler Build...-img_0618.jpg
    I used some Omix-ADA 97-17 universal buckets and bezels (I'm not super impressed) and some Amazon LEDs I also installed some LED fog lights in the stock buckets with some slight modification. My main reason for the update (aside from going full mall crawler with this jeep) is because of how yellowed and hazy the stock light housing were. The only other parts I needed were the correct light adapters, most LED's have an H4 style plug that works with CJ/TJ lights and they include the correct adapter for the JK (H16 I believe) the Liberty uses a 9007 bulb. I found the adapters on Amazon for $4.99. So in spite of what Google tells you, you can adapt 7" round headlights in a liberty with very little work and modification.
    Just
    Empty
    Every
    Pocket
  18. #78
    eric m's Avatar
    Oct 2011
    Millersburg, Oh
    441
    I haven't updated this in quite a while. Figured I would post some of what I've doing to the TJ. Still need a frame but I have a lot of other stuff to do to keep busy till I get one.The Cheap Wrangler Build...-img_2429.jpgThe Cheap Wrangler Build...-img_2441.jpgThe Cheap Wrangler Build...-img_2444.jpgThe Cheap Wrangler Build...-img_2445.jpgThe Cheap Wrangler Build...-img_2448.jpgThe Cheap Wrangler Build...-img_2450.jpgThe Cheap Wrangler Build...-img_2451.jpgThe Cheap Wrangler Build...-img_2453.jpgThe Cheap Wrangler Build...-img_2458.jpg
    One of the projects that I've been planning for the TJ is to put on this Scrambler half-cab I picked up back in 2014. I cut the roll-bar off behind the main hoop, bent it forward, shortened the windshield frame tie-ins and re-installed the sound bar (this temporary as I will install a front cage kit prior to taking it off-road). I made the bulkhead out of 16ga steel plate and 1/4" x 1" thin walled box tube. I did a rough trim on the front edge of the hardtop and installed some latches I had in my parts box. The top will be further modified (some areas need repaired). I will keep this updated as I make and install some aluminum corner armor and do some panel repair as time allows.
    Just
    Empty
    Every
    Pocket
  19. #79
    eric m's Avatar
    Oct 2011
    Millersburg, Oh
    441
    Started on my aluminum corner armor and my round led tail lights. The Cheap Wrangler Build...-img_2501.jpgThe Cheap Wrangler Build...-img_2502.jpgThe Cheap Wrangler Build...-img_2504.jpgThe Cheap Wrangler Build...-img_2505.jpgThe Cheap Wrangler Build...-img_2508.jpgThe Cheap Wrangler Build...-img_2509.jpgThe Cheap Wrangler Build...-img_2510.jpgThe Cheap Wrangler Build...-img_2511.jpg
    Just
    Empty
    Every
    Pocket
  20. #80
    eric m's Avatar
    Oct 2011
    Millersburg, Oh
    441
    My buddy got all the wiring sorted out to use the original tail light plug (while I worked on shaping and drilling the corner). These are nicer than the generic round sink in lights as they have a white reverse light ring. I still need to replace some steel behind the corner, but that will be done when the tub is off.
    Just
    Empty
    Every
    Pocket
  1. Scubadude's Jeep Build - 2007 Wrangler JK
    By ScubaDude in forum Jeep Builds
    Last Post: 09-18-2015, 08:19 PM
  2. F.s. Wrangler top cheap!
    By unclebill in forum Items for Sale, Trade, or Give Away
    Last Post: 10-27-2009, 05:35 AM
  3. 15x10 american racing outlaw 1's for sale cheap cheap cheap
    By kibblepuppy in forum Items for Sale, Trade, or Give Away
    Last Post: 06-07-2006, 10:18 PM
  4. 2002 Wrangler SE - MUST SELL - CHEAP!!!
    By RompIT in forum Items for Sale, Trade, or Give Away
    Last Post: 11-29-2005, 08:24 PM
  5. 93 wrangler 4.0 manual for sale so cheap
    By jhiggins in forum Items for Sale, Trade, or Give Away
    Last Post: 11-04-2003, 11:24 PM
