1994 Grand Cherokee Laredo Hard Starting
lleach1
My 94 GC Laredo 4.0 4x4 auto is difficult to start when at operating temp. It seems to be temp related. It starts fine cold or after running a short time before temp is up to normal. Replaced Coil, Distributor Cap, rotor, pickup, plugs & wires, fuel pump, fuel regulator, fuel filter, air filter, crank shaft position sensor, cam shaft position sensor. Runs great once it starts. Usually starts on third attempt after trying two short attempts (ignition on crank five seconds ignition off, ignition on crank five seconds ignition off, ignition on crank and starts immediately). I am really out of ideas. Update 09/07 PM. While driving today in traffic the engine shut off as if the ignition was suddenly switched off. No warning lights, nothing with the ignition still in the ON position. Turned it of & back on, the warning lights came on and it started immediately and ran smooth as silk until later in the day when it did the same thing again, twice. Would appreciate any ideas. :???:
