When I started my 2000 TJ today, the check engine light was on.  I tried to read it with my OBDII reader, but it won't connect.  The odometer display shows "no bus".  None of the instrument cluster dials moved from zero.  Fuel, voltage, tachometer, speedometer, oil pressure, coolant temp, all pegged all the way to the left, like the car is turned off.  The Airbag light and CEL lights are lit.
It starts. I can drive it. The "no bus" display on the odometer comes and goes while I'm driving, but it's mostly "no bus". When "no bus" disappears, my needles all respond normally and the odometer shows the mileage. Then a few seconds later, the needles go dead and "no bus" appears again.
Maybe an electrical problem? Or ECU going out?
Has anyone experienced this before? Any ideas on what to check?
