97 cherokee 4.0L LOSE OF POWER AND PUTTERING
bigred2683
I need some help i have a 97 cherokee 4.0 4x4 it spits and spurts on and off i can crank it up and runs smooth sometimes for hrs but sometimes it acts like it wats to shut and starts suttering i have replaced the destributor,cap, rotor and plugs and wires and map sensor and battery an i have done a fuel pressure test on it and everything passed but still have have the issue has anyone ever had the problem and can anyone help me figure it out
Have you tried some injector cleaner? Maybe there is some junk in the system.
Sent from my SM-P600 using Tapatalk
Move the wires to the Crank Position Sensor and see if you can make it run rough. That model is known for a short in the wiring to the CPS. Could also be a bad CPS.
