99 TJ engine dies without warning
Jhardage
My 99 TJ engine will shut off at any given time. When it first started shutting down the TJ would die once a day. Now it dies almost immediatly after cranking. Sometimes it will start right back up and sometimes it will take an hour or two before it starts. When the engine shuts down, the spark plugs will not fire. I've changed the dist. cap, rotor, plugs, wires and coil. Any suggestions?
I know these items don't have anything to do with the ignition but I've also changed out the fuel pump and throttle body since the problem started.
