a little 2 questions ......
interceptor429
#1.any photo's of fuse box underdash that shows what fuse goes where ?.
#2 how do you remove the cigar/cigarette lighter socket.....mines not working and i need it ...i think fuse is good ,,radio works .can't find anything on search,.....thanks guys and gals ....:D
oh it might help 1994 4.0 HO cherokee
To replace the lighter you have to take off the plastic cover for the dash, should be like 6 little screws and then there's just a couple that hold the lighter itself on, fairly simple job man, and here's a diagram of the fuse box.
thanks ,.....i got lighter fixed it was power wire vibrated loose i guess i pulled it off and put back on and it worked ...good fix...now i found a vacuum line burnt into .looks to go into a metal line on drivers side going under truck .....burnt at the valve cover bach passenger side near a canister and heater control valve lines ...can't find the other end ...too dark for pictures ...:redface:
A vacuum line running by the carb bowl on the passenger side, ill take a look man, see if I can't figure out which line that is Lord knows there's alot of them lol
