Most of my reading has been with the Renix (might or might not be the same or close, with the OBD). one circuit to the ECU was for high idle (A/C select circuit), another to widen the injector pulse band width (A/C request circuit)(and turn on the compressor relay and aux fan), which sounds like a little richer to me. Just a guess, but the wider pulse band width, probably gives it just a touch more umph at lower RPM´s and might also help with motor cooling a bit, auto 101 taught me, that a rich motor ran cooler, than a lean motor.
The wider pulse band width, could maybe foul the plugs during prolonged idle or heat up the CAT.
I have unplugged the compressor and turned on the A/C, to get the higher idle and aux fan, when doing a lot of low speed wheeling. It´s a quick way to put the aux. fan on, to prevent overheating (if you don´t have a switch wired in, to turn the aux. fan on, before it gets hot) seemed to add a little extra torque to boot. May have just been the higher idle. On many police models, there is a switch to turn on the high idle. Could probably do the same thing, with the A/C request circuit (turns on the A/C relay/aux fan and widens pulse width) at the ECU and widen the pulse band width without the higher idle. Pulling the A/C relay would give you the higher idle and wider pulse, without the compressor or aux fan, with the A/C on. At least on the Renix.
I´m doing gaskets and seals this week, but plan on adding some switches and options, soon.
A/C controls on, compressor unplugged = interior fan, aux fan, high idle and wider injector pulse.
A/C controls on, compressor relay pulled = interior fan, high idle and wider injector pulse.
A little creative wiring, could give you more choices. Might turn out to be an acceptable poor mans, adjustable MAP.
